Rattle noise
It is a 2.2. Noise is coming from under truck. Can be heard with truck standing still with engine running. I've heard these trucks have a shield on the exhaust that sometimes works loose. I'm going to try to check that today.
I checked it out today; still unsure of where it's coming from. I got under the truck and checked the exhaust. It looked very solid..no loose shields or anything. Then I noticed the noise wasn't down there, it was toward the front of the truck. I raised the hood with it running in park with AC on (that's when it makes the most noise) and still couldn't pinpoint it. At least I'm pretty sure it's not the exhaust now.
My compressor rattles slightly. I'm wondering if you have the same problem. Does it only do it when the compressor engages?
Did you first start to notice it when in a drive-thru or while you were parked idling next to a wall or fence? Thats the only time I hear mine doing it.
I'm sure it rattles loudest when the AC is on and definitely more noticeable when next to a wall, another car or something solid. It also seems to be louder when driven for awhile, or warmed up, I guess. A friend gave me one of those engine stethoscopes, might be a good time to try it out. It's definitely a constant noise. Thanks
