S10 & Blazer DIY and Useful Threads This section is strictly for frequently asked questions pertaining to S10s and Blazers.
2wd stock swirl alloys on a 4wd
Old Aug 6, 2017 | 1:54 PM
Lvgx3's Avatar
Default 2wd stock swirl alloys on a 4wd
I own a '96 Sonoma with the alloy swirl rims will these fit on a '04 4wd blazer?
Old Aug 18, 2019 | 12:13 AM
Joels Johansen's Avatar
Default Difference in Wheel space and offset
what matters are 3 main factors ;Bolt pattern. Offset and Caliper clearance. Check Rimhelp.com or wheelhelp.com. its only likely if you apply , maybe a correct wheel spacer on the front axle because the 2004 4x4 blazer has a High offset and the older 2wd rims (if they are the alloys' and not just straight steeelies. the "older ones just have medium or Low offset, and the Bolt pattern is similar 5 X120.7 mm wish you some good luck on this ( :FYI i own 2 sets of rims for the 4XJimmy and ; also 3 sets for the Sonoma 2wd LOL
Last edited by Joels Johansen; Aug 18, 2019 at 12:18 AM. Reason: simple explaining
g_unit
Nov 3, 2017 10:06 AM
EvansBlue
10
Aug 12, 2016 9:24 PM
PtownBubba
Mar 29, 2011 3:19 PM
Tutu
Aug 3, 2009 7:15 AM
92chevysilvy
May 11, 2009 5:07 PM
