Truck starts for a second then dies. No codes
First the truck is a 1999, It the body style of the 1998. Second thing is that I drove the truck the day before and I ran fine. I parked the truck and the next
morning it would start and immediately die. No
check engine light or codes with my scanner. I have
replaced fuel filter, fuel pressure is 60psi, replace
cap rotor and plug wires, ignition coil, mas air flow
sensor. There was no change. Where should I go
from here? Crankshaft position sensor, o2 sensors,
throttle position sensor, intake air valve?
Instead of throwing random parts at it, do some troubleshooting to help narrow down the problem. Combustion needs three ingredients.
Did you test the plugs for spark?
Try spraying starter fluid down the intake and see if that makes it run longer.
Sounds like passlock problems. Is your security light flashing with the key in the on position? Try to reset the passlock system by trying to start the truck then when it dies leave the key in the on position for 10 -15 minutes, until the security light quits flashing and is on solid, then start the truck without turning the key to the off position first. It should start and run, if it runs fine then the passlock has been reset and you can shut it off and be good to go.
You both need to read what's posted and try the basic troubleshooting first.
Ianmac
1988 - 1998 (GMT400)
21
March 22nd, 2020 11:34 AM
Kamelred408
January 15th, 2020 4:02 PM
Mason.Griffis
January 13th, 2020 8:32 PM
