Still acting up
Old Mar 29, 2022 | 10:01 PM
bigblocksteven's Avatar
Default Still acting up
Hi everyone, Iv got a 1995 chevy Silverado 2500 extra cab long bed TBI 454. It’s my camping rig so I try to keep it tuned up and Iv been having some issues I haven’t been able to pin point. So far Iv done fuel pump, fuel filter, rebuilt tbi, idle air control valve, throttle position sensor, map sensor,both temp sending units, plugs, wires, coil, cap and rotor. Fires right up but as it warming up right between cold and Normal operating temp it goes to idle down and stumbles and dies but will fire right back up, Also when put in reverse will try to die it’s worse when it’s really cold out side. Another thing is while driving it if I give it a lot of throttle it backfires in the intake. If I’m just cruising it around it’s fine next in my list is a new distributor cause I’m pretty sure it’s the stock one and it’s little rough looking inside it truck has 230,000 miles on it. Any ideas? Thanks
Old Mar 31, 2022 | 1:55 AM
oilcanhenry's Avatar
Originally Posted by juliann
it's maybe the engine itself
LOL!! I've never cared for the 454 motor either. A good 5.7 is much better. Even the old 400 cubic inch (6.55 l) small block is better.
Old Mar 31, 2022 | 1:58 AM
Can you find someone with an OBD I code reader? It sure would help us Dx your 454.
Old Mar 31, 2022 | 9:51 AM
Check engine light only came on once in this truck and after I replaced the tps and map sensor it cleared. I was thinking maybe the ignition control module going bad cause I’m pretty sure it’s original from 95 and when I did the cap and rotor it was pretty crusty inside the distributor.
Old Apr 4, 2022 | 7:44 PM
It wouldn't hurt to get in there and clean things up a bit. Might prevent future problems or issues.Best of luck to you!
Old May 17, 2022 | 8:51 AM
FrancesLanphear's Avatar
Hi, I am sorry I don't have enough information regarding this. But yes, if you want to do your essay assignment and searching for someone who can do your essay assignment. Then you can visit https://www.topessaywriting.org/edit-my-paper here to you will find an essay writer who will do your essay assignment. I also use that website to hire an essay writer.
Old Yesterday | 9:53 PM
sofiawiayz's Avatar
Hi everyone, Iv got a 1995 chevy Silverado 2500 extra cab long bed TBI 454. It’s my camping rig so I try to keep it tuned up and Iv been having some issues I haven’t been able to pin point. So far Iv done fuel pump, fuel filter, rebuilt tbi, idle air control valve, throttle position sensor, map sensor,both temp sending units, plugs, wires, coil, cap and rotor. Fires right up but as it warming up right between cold and Normal operating temp it goes to idle down and stumbles and dies but will fire right back up, Also when put in reverse will try to die it’s worse when it’s really cold out side. Another thing is while driving it if I give it a lot of throttle it backfires in the intake. If I’m just cruising it around it’s fine next in https://tropical-casino.com/ my list is a new distributor cause I’m pretty sure it’s the stock one and it’s little rough looking inside it truck has 230,000 miles on it. Any ideas? Thanks
The backfiring in the intake suggests there might be a timing issue or a problem with the ignition system, especially since you're considering a new distributor. Given the mileage, replacing it could be a good move if it looks rough inside. Additionally, check the spark timing and ensure it’s set correctly.
bjurel
Apr 17, 2024 7:47 PM
ChevyG30
Apr 14, 2019 5:43 PM
bigbossman7801
Mar 3, 2012 6:30 PM
Unknown1329
Feb 21, 2012 10:18 AM
dirttrack
Sep 9, 2011 4:25 PM
