TrailBlazer 2002-2009
2006 Trailblazer LS steering position/angle sensor
Old September 2nd, 2024, 3:34 PM
RJ Hall's Avatar
Default 2006 Trailblazer LS steering position/angle sensor
I've got a 2006 Chevy Trailblazer LS, with the 4.2l in-line 6 motor.
I got this vehicle about 6-7 years ago and when I got it the dual warning lights were on, indicating the steering angle/position
sensor was out (most likely).
I replaced it with a Dorman brand sensor. Some of the Youtube video's and guides showed this as being a pretty difficult job
but honestly, it wasn't that bad.
This worked, the warning lights were off after the reset, problem solved. Fast forward to last year. Same problem. So I did the
same thing again, but honestly I messed up. I had secured the steering wheel but I accidentally moved it. I went through with
the replacement anyway and it worked for about 3-4 days then the warning light came back on. I just assumed that this was my
fault.
About 2 weeks ago I finally got around to replacing it again. I went with Dorman again because it lasted about 5+ years the first
time and I sincerely believe that the second one was my fault due to moving the steering wheel. I made absolutely sure I didn't
move the steering wheel this time (duct tape, for the win!).
Unfortunately, it only lasted about 2 weeks and the light came on today. On a straight stretch, at about 35-40mph. As soon as
I got home I turned it off and back on again a couple of times and it didn't come back on but I can only assume that, like before
it's going to get worse.
So my question is, since I am 100% sure I installed it correctly this time, what else could it be or is there something that is causing
the sensor's to go bad prematurely?
Thanks all.
Old September 2nd, 2024, 4:52 PM
Gumby22's Avatar
What is/are the trouble codes being set?
Is the alignment good and the steering wheel centered when driving straight?
Old September 3rd, 2024, 12:34 PM
RJ Hall's Avatar
I've not gotten the codes yet. Next time I'm out to town I'll see if any are there (history) since it only did it that one time
after this install.
I had a front end alignment done last year after I put in new outer tie-rod ends and CVS (wheel bearing) units. As far
as I know, it's okay. It seems centered when I'm driving on a straight stretch of 4-lane road.
Can that cause the 2 warning lights on the dash to come on?
Thanks.
Old September 3rd, 2024, 1:34 PM
Gumby22's Avatar
Depends on what the sensor is actually reading when it’s being driven straight. If it’s near zero degrees then probably not - if it’s offset to the left or right by more than 5 degrees then it could be.
Which warning indicators were you getting?
Old September 3rd, 2024, 1:45 PM
RJ Hall's Avatar
These two:
Old September 3rd, 2024, 7:07 PM
Gumby22's Avatar
The one on the left is “Service Stabilitrak” - the one on the right is the Stabilitrak indicator which comes on only when the system is active, manually switched off, or disabled due to a fault (see page 3-41 of the owners manual for more detail).
The SWPS is a very common cause of stabilitrak problems but there are several other possible causes as well, especially on a vehicle that’s 18 years old.
I’d recommend getting the codes pulled by a shop with a factory equivalent scan tool (or a dealer if need be). Parts houses can typically only pull codes from primary modules (PCM/ABS/Airbags) which may not have any useful codes stored.
The Stabilitrak system is controlled by the ABS module, but the steering wheel position sensor is a “smart sensor” meaning it’s both a sensor and a module in one assembly. IIRC, you actually have to build the vehicle as a 2007 with the scan tool in order to read data/codes from the SWPS.
Old September 4th, 2024, 10:00 AM
RJ Hall's Avatar
I'll be going out today so I'll stop by at a couple of places and see if they can retrieve any codes and report them back here.
Thanks.
Old Today, 12:15 AM
RJ Hall's Avatar
Well, things continue to be interesting...and mysterious. No easily solvable solutions here.
I stopped by O'Relly's, Advance Auto Parts, and Auto Zone to check for codes after the warning lights came on. This all took a while because I had
to wait until it flashed on. It still just comes on at random times and sometimes not at all.
The thing is, they detected no codes whatsoever - completely clear. Nothing in history either.
I was told by the workers at these places to wait until it came on, then bring it by without turning the motor off so they could check it. Well, I did that
and guess what? With the warning lights active on the dash, and the motor running, still none of the places above could get a code. Completely clear.
So...besides the steering angle/position sensor, what else could be causing the warning lights to come on?
Thanks <pretty baffled in Kentucky>...
Psycho4190
March 4th, 2023 10:41 AM
121
March 17th, 2021 7:57 PM
tommywass
October 18th, 2014 9:05 AM
tommywass
September 12th, 2014 8:20 PM
LippinOff
February 12th, 2012 5:40 PM
Quick Reply: 2006 Trailblazer LS steering position/angle sensor
