2002 GMC Savana 1500 Conversion Van - Alternator
I'm chasing an alternator / charging issue that should, of course, have been a very simple fix. I believe I've narrowed it down to what appears to be an inline fusible link in the main power feed between the (+) battery and the alternator.
QUESTION 1: Harness - can the (+) harness be purchased as an assembly so that I can replace all 3 of the heavy gauge wires coming off the (+) side of the battery (starter, alternator, fuse box)? If so, anyone know a part number and course?
QUESTION 2: Fusible Links - can anyone point me to a part number and source for the individual fusible links on the 3 heavy gauge wires?
Thanks for the help
Thanks for the help
I don't know the specific part numbers, but it appears 3rd parties stock things like the battery cable, starter cable, and alternator cables:
https://www.rockauto.com/en/catalog/...ery+cable,2500
May not have all you need, but its a start.
I'm looking for the 3-wire harness, with the fusible links in them. I can't figure out what the amperage rating of those links is via Google search. So was hoping buying OEM would get me there
I just picked up some ATC fuse holders and 30A fuses from the hardware store. I have some smaller fuses at home (15A, 20A, etc) and will start with those. I'm just going to cut the fusible links out of the OEM harness and solder / heat shrink these new fuse holders in. That SHOULD fix the problem - fingers crossed.
UPDATE - issue fixed. After all of the farting around, it ended up being the F wire going into the back of the plug in the alternator. Once I narrowed it down to the plug (while installing a manual switch as a ghetto bypass) I realized I was getting 12VDC to the wire as it enters the back of the plug, but not at the female pin. So the wire itself, or the crimp, failed there. I cut the connector off and then soldered in a new one. I happened to have a few new 4-pin plugs / receptacles in my misc electronics bin. I only used the center 2 of the 4 wires though.
So anyway, all fixed up.
BurntClutch (Today)
gingerpunkster89
February 6th, 2013 1:50 AM
