Fuel tank access hatch....
Yes, I did it using an angle grinder with a cutting wheel on it. Basically, it's right under the hump in the middle. One of the mistakes I made was not making the forward most cross-cut far enough forward, so I had to cut out some more.
The bigger mistake I made was putting a tiny, almost invisible slice in the fuel line! Looked like nothing until I turned on the ignition and a small fountain of fuel shot out. I knew the lines were there and I thought I was being careful enough, but wasn't. My advice would be, when you make the right-side, front-to-back cut, only cut deeply enough to be able to bend the hatch back and forth until in breaks off completely. That will eliminate the chance of hitting the fuel line.
I fixed it by running a new fuel line from the pump to the filter and took the opportunity of replacing the fuel filter that was very old, so, all good.
Also, the edges of the cuts are going to be very sharp, so do what you can to grind or file them smooth. I also but gorilla tape (duct tape) around the edges. I was going to put hinges on the hatch but didn't bother — just put one of the rear floor mats over it and reinstalled the seat.
Bought the car used from Hertz 22 years ago, still runs great, doesn't burn a drop of oil.
dberladyn
Aug 12, 2015 7:56 PM
