88 305 no start
Old Today | 9:05 AM
DifferentZ's Avatar
Angry 88 305 no start
Hey everyone. Recently rebuilt an '88 Camaro 305 to go in my 78 280Z. Different, huh? Anyway, The engine backfires through the intake manifold (blowing gas out the top of the carburetor. I tripled checked the timing (including pulling the timing chain cover) and confirmed the distributor was pointing to #1 cylinder. I even removed the intake manifold & valve covers to visually see if all the valves were closing. I didn't pull the camshaft (though I probably should have) when I replaced crankshaft and connecting rod bearings, but noticed the engine has roller lifters. Did Chevrolet use roller lifters in 1988? Do you think the cam could be causing the backfire issue?
I have the engine on a run stand. The engine got hot and cooked the main bearings. I think the oil pump went out.
I'm a bit frustrated at the backfire issue and am interested in any opinions about what it might be. Kinda like another set of eyes.
Thanks in advance for any and all opinions on what the problem might be.
Old Today | 9:51 AM
Rednucleus's Avatar
Double check that your plug wires are in the proper order and that you distributer is not 180 degrees off
novaguy42
Nova & Chevy II
Oct 19, 2014 11:30 AM
Racingman9977
Jun 28, 2014 8:25 AM
greendragon13
Oct 15, 2012 8:37 PM
baracis
Dec 3, 2010 9:39 PM
