Missing the mass air flow sensor plug
Old Yesterday | 12:27 PM
Uncle Wick's Avatar
Default Missing the mass air flow sensor plug
I have an 04 express 2500 4.8 I have had to do a bit of work to since I bought it used. I have another problem I cannot find a solution to anywhere. When I bought it. It was missing the mass air flow sensor and the plug had been cut back about 6 inches. I replaced both with new but the replacement plug has different color wiring. I have looked everywhere and found multiple color pin layout. None have the colors I have.
I have: 2 tans, 1 pink, 1 yellow, and 1 black w/white stripe.
Thanks for your time.
Old Yesterday | 5:11 PM
Triaged's Avatar
Try this. https://lemon-manuals.la/Chevrolet/2...nsor/Diagrams/
Old Yesterday | 7:14 PM
Uncle Wick's Avatar
Perfect. Thank you.
At the risk of sounding ungrateful, how do I determine D from E? If I knew the ECM pin for the IAT I could OHM back between the two tan wires. Unless you know an easier way.
again, I am very grateful for this information. I am light years from where I was.
Old Yesterday | 10:07 PM
Triaged's Avatar
That is odd... Test with volt meter to ground and E should have some voltage while the other shoes 0?
Kimberley
Silverado DIY and Useful Threads
Jun 1, 2025 5:49 PM
tskier
Feb 8, 2020 1:00 PM
tommy7189
Jan 14, 2008 8:29 PM
car56
Oct 10, 2006 6:33 PM
