Front wipers not working recall
Just tonight, my windshield wipers were in use, and when I went to adjust the speed of them, they stopped working. I checked the #25 fuse under the hood and it looked good, but replaced it anyways and no luck. Read somewhere that the motor can overheat in tough conditions and it would restart when it cooled down, but this was only in use during a slight drizzle? Any idea if this is the motor or the internal circuit breaker? No sound coming from the wipers when they are turned on. This is a 2010 Suburban. Any ideas on how to fix would be appreciated. Thanks
This is a very serious design issue that needs to be addressed ASAP by GM with a recall. If your wipers have stopped on your Equinox in heavy rain and you have had to repair it with a new Transmission Wiper Linkage part: send a letter to General Motors, PO Box 33170, Detroit MI 33170-5170. I have notified GM of this issue which is a fatal problem. Please submit your story with claim # 8-2261613426 for them to compile this information to see if this can be considered as a recall. It will not happen with out you notifying them that you are having the same problem, and it could happen again if this design is not corrected. Please help me address this issue before someone becomes fatality. Please pass on to all Equinox owners.
I have a 2018 Chevy Equinox and was caught in a very bad predicament tonight. I was going home from work and we had a bad storm . My wipers did this exact same thing. Stopped working as soon as i needed them to work the most. I have been looking online and it seems like the 2018 model isn't even considered on any of the recalls for this same issue that all previous models are having.
Matthew David Zidar
April 27th, 2014 10:46 AM
