Scraping noise after clutch replacement
Old January 16th, 2018, 11:23 AM
Billyg1124's Avatar
Default Scraping noise after clutch replacement
Hey, so I just replaced my clutch and added a bell housing cover( after not using one) and when I go to start it , the engine just gives a scraping sound , once every revolution, near the bell housing. The cover has no scratched on it though. Chevy 350 SB
Old January 16th, 2018, 11:49 AM
kevinkpk's Avatar
Bell housing cover? Is this the dust cover on the bottom?
Old January 16th, 2018, 12:14 PM
Billyg1124's Avatar
Yes kevin
Old January 16th, 2018, 12:30 PM
kevinkpk's Avatar
Is it scrapping (sound) with it off?
Old January 16th, 2018, 1:13 PM
Billyg1124's Avatar
Yes , I took it off, played with with the clutch and the tranny, nothing . I don't think it has anything to do with the cover but it's a difference to originally so I said it.
Old January 16th, 2018, 1:55 PM
kevinkpk's Avatar
Can you post a vidio?
Old January 16th, 2018, 1:57 PM
kevinkpk's Avatar
Did you pull the flywheel, also did you replace the pilot bushing, or grease it?
Old January 16th, 2018, 2:19 PM
Billyg1124's Avatar
I did replace the flywheel and greased the bushing. How do you add a video? I can only do pics
Old January 16th, 2018, 2:37 PM
kevinkpk's Avatar
Same way you do pics. Is the flywheel "square" on the crankshaft? Tha'ts a common thing, but usually the starter will whine.
Old January 16th, 2018, 3:28 PM
Billyg1124's Avatar
It rests on the guide , the center of the flywheel fits over an extended part of the crankshaft. And It won't let me do a video
