Use of a Oil Change Pump
Magnetic drain plugs are better then using a dipstick oil removal plug. You have to change the
oil filter anyhow.
oil filter anyhow.
Thanks for your replies, but me let rephrase the question. Does anybody know, based on the shape and angle of the Tahoe oil pan will a Oil Change Pump remove all of the oil.
The reason I'm interested. I just bough a Mercedes and there is no need to go under the car, the oil filter is on top, so thinking about buying a pump anyway. I just moved to a townhouse, technically your not allowed to repair cars in the driveway. I though it would be more discrete to quickly jack up one side, r & r the oil filter rather than have the Tahoe sit on ramps for the whole procedure.
Thanks again
Sal
Thanks again
Sal
My last Wrangler had the filter on top. You'd think Fiat was a freaking genius for that.
well, I can't say you will get "all" the oil the drain will get, but I don't see why a pump wouldn't work. The dip stick tube goes right to the oil pan.
This is what we use the boat world:
As far as I know you'll still have to get under the tahoe for the filter...
Thanks again
Sal
Thanks again
Sal
