2016 suburban, brakes don’t work at slow speed ? Need fix
Old September 18th, 2018, 12:30 AM
AnnnaMot's Avatar
Default 2016 suburban, brakes don’t work at slow speed ? Need fix
i have a 2016 suburban and I’m having a problem with the brakes, at slow speeds the brakes don’t work , I changed the master cylinder a few months ago when I was having the same problem, now it’s doing it again. Has anyone had the same problem and can help
Old September 18th, 2018, 12:51 AM
oilcanhenry's Avatar
Your POWER brakes are not operating properly?
Old September 18th, 2018, 1:43 AM
AnnnaMot's Avatar
I know that part I need a fix , I’m sure someone has had this problem before
Old September 18th, 2018, 2:12 AM
IME, your power brake vacuum booster has suffered an early breakdown. You need to make the dealership repair it under warranty.
