How to cam swap
How to cam swap
Hello this is my first time on this site and I'm currently new to this whole idea of swapping cams, I've done some research and I would like to perform a cam swap, I have a 2001 chevy Silverado 1500 with a 4.3L V6, throttle body if that helps any. I have lots of questions regarding how to do one correctly and what all needs done in order to make this a smooth install after I'm done. My main goal is to give it a more choppy "aggressive" sound to it, I'm not sure which cam to go with or what else I need to do or buy with it or any steps that need to be done in order to make this happen. Thank you for helping out!
Hit a cam website,see how aggressive you can go,my thought is a small step up from stock will cause less headaches,the 4.3 is in alot of boats,so in those they use a r.v.cam or boat cam,same thing,low end torque
