RPMs dropping with more throttle on Chevy Small Block
Old November 20th, 2018, 6:30 AM
Szobod's Avatar
Question RPMs dropping with more throttle on Chevy Small Block
I have a small block Chevy 350. When attempting to accelerate, the rpms drop. The engine seems to not want to exceed 3000 rpms. I've cleaned the carburetor and attempted to adjust ignition but these haven't helped. Any thoughts as to where I should begin?
Old November 20th, 2018, 6:39 AM
kevinkpk's Avatar
Is it a Rochester? Is the float set on the carb? Might be too low, and starving for gas.
Old November 20th, 2018, 7:37 PM
Szobod's Avatar
Hi there. Thanks for your quick response. It's an Edelbrock. I will check the float this weekend. Another thing I noticed, 3 out of 4 pipes on the exhaust manifold on one side of the engine are not as hot as the 4 on the other side. Is this normal?
I'm hoping to fix this myself as it's mounted on an airboat making it difficult if not impossible to take it to a mechanic.
Old November 21st, 2018, 7:30 AM
kevinkpk's Avatar
Check the float drop first.
