97 gmc 5.7l
97 gmc 5.7l
Runs rough and very rich, the check engine light is flashing! It was stumbling at low RPM and I changed the plugs. It got way worse!?
The question is why?
Any guidance / suggestions would be appreciated.
on
Like what Irish said, check wires, etc. Hell, I put in new plugs, wires, one-at-a-time even and cap/rotor and still managed to get #3 and #5 crossed over!
Easy to knock a vacuum line off too, check all the obvious.
This little reader is great for the money. Does the basics plus a little more. Just hook it up to you laptop and see what's going on.
Thanks all, I have traced all the plug wires, all on correctly, I replaced both upstream oxygen sensors, no change. I did unplug the mass air flow sensor and 'no change' at idle. I will double check the vacuum lines and head to the pawn shop and buy a nice scanner my buddy Kelli has for $50!
I'm here for the party
ok lets start with the basics. double check your plug wire connections and make sure you didnt cross number 5 and 7 wires. then test your fuel pressure
Thanks for the suggestions.
