92 K 2500 air conditioning problem
My air conditioning compressor pump is not staying on long enough to cool down my truck. I have a 92 K 2500. initially the compressor turns on and off ( doesn't stay on very long) and then the compressor won't turn on at all. It behaves as though the system thinks that the temperature in the truck is cool enough even though I have turned the control all the way to the coolest temperature. If I bypass the compressor pressure switch on the condenser the compressor will stay on and the truck will cool down.
Maybe I need to replace it again, I think I'm going to buy the gauges to measure the high and low pressures to see if the switch is working correctly or not. Appreciate your input.
