Notices
04 Silverado 1500 Z71 Leveling
Old July 2nd, 2014, 1:27 PM
chevytruckman2004's Avatar
Question 04 Silverado 1500 Z71 Leveling
I want to lift the front of my 04 Silverado 1500 Z71 to be level with the rear. I only need to lift it about an inch and a half in order to level it out. I know you can lift the front of your truck by turning up/down the torsion bars but I have heard you can't lift them very much by doing this. Any information/help on how to do this?
Old July 2nd, 2014, 5:15 PM
country_09's Avatar
Depending on the condition of the bars (if they've never been messed with, you're prolly good) you can get 2" easy out of them. Will be plenty for what you're lookin for
Old July 2nd, 2014, 6:11 PM
old dog's Avatar
Default z-71
if you can get enough adjustment out of them you will have to get a frt end alignment . if not get a set of frt sway bar key's that will lift it enough . this is a sample
Revtek® 332 - Chevy Colorado 2004-2010 Suspension Front Leveling Kit
Old July 3rd, 2014, 11:09 AM
ok thanks
Old July 3rd, 2014, 11:20 AM
what about using coil spring boosters?
Old July 3rd, 2014, 1:34 PM
old dog's Avatar
Default lift
that only work's if you have coil spring's ,torsin bar's use keys coil over strut's use spacers .
Old July 3rd, 2014, 1:51 PM
it has coil springs on the front
Old July 5th, 2014, 2:08 PM
country_09's Avatar
If it's z71 it'll have torsion bars. If it's 2wd then it'll have coil springs. You should have torsion bars bein z71
Old July 5th, 2014, 4:34 PM
old dog's Avatar
some have gone to coil over strut suspension on the new one's you will have to look under the front to see if it has coil over's or just torsion bar's .
Old July 7th, 2014, 12:58 PM
ok i thought i had coil overs but it has torsion bars, i was thinking of my other truck
Quick Reply: 04 Silverado 1500 Z71 Leveling
