383 stroker help! 2000 silverado
hello, i have a 2000 chevy silverado ext cab z71 with a 5.3 vortec. my dad is a machinest and highly qualified mechanic. we want to swap my 5.3 for a 5.7 and stroke it to a 383 stroker. what i want to know is what complications will we cross? i relize the intake wont fit but what else will i need to change or swap such as computer, tbi, exhaust, motor mounts, intake manifold, exhaust manifolds, all the componants like ac, alternator, power steering pump etc .or would u have the specs or a recomendation to build up the 5.3 or a stroker kit for it? any information is highly apreciated thanks
RE: 383 stroker help! 2000 silverado
I think you should ask a highly qualified mechanic.
Unless things have changed in the last few years all the externals should be a direct bolt on. If you can get a complete 5.7 form air cleaner to cats, and computer that would make it easier though. Your engine mounts and radiator and hoses should work fine. If you do find a 5.7 and decide to put that in Summit racing has a 383 stroker kit for the vortec engines. It cost around 1000 dollars.
Their # is 1-800-230-3030 Good luck |
just build up your 5.3 liter. it will be better in the long run because you wont have to worry about having to do any rewiring to the harness.
You won't have to re wire anything!
All external parts bolt up But a 383 is kind of a waste because of all the extra parts I would look into a 6.0L block and stroke it to a 402ci Then use L92 heads and L76 intake and bam Good to go Or look into a 370ci |
Originally Posted by Exhausted
(Post 208954)
All external parts bolt up But a 383 is kind of a waste because of all the extra parts I would look into a 6.0L block and stroke it to a 402ci Then use L92 heads and L76 intake and bam Good to go Or look into a 370ci "Speaking from experience" If I were you I would spend the extra money and and get a reinforced race block and start from there and build it up |
How do you build a 5.3 to match the HP of a 383?
Originally Posted by BullyDawg
(Post 208946)
