Add oil
I have to constantly add oil to my 2007 Silverado. I have never had to add oil between oil changes (86, 90, 94, and 98 Silverados) but do now 2-3 times between oil changes. I added 1/2 qt Friday, drove 250 miles and have light on Monday. Is there a problem or is this normal with a hotter running engine?
I change my own oil and use synthetic 5-20. Would a heavier oil help? |
Originally Posted by Flipg8tor
(Post 195023)
Assuming you have a 5.3 they are known to use a little bit of oil but this seems to be a bit excessive....
I go through a quart of oil a week in my 92 chevy cheyenne, but thats cause I have 263,000+ miles :D
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Flipg8tor,
That seems like it is a little excessive. There are no leaks that you are aware of? Any puddles in your driveway? Have you had this checked out, yet? I would definitely. Let us know what else you find out. Breanne Chevrolet Customer Service |
I did check drive, no oil. Also visual underside and no sticky places. Change my own oil so checked filter and plug, no leaks.
