grinds going into 4 low
i have a 94 k1500 with a 5.7 and 4 hi works fine but when i try to put it in 4 lo it makes a grinding sound. when the truck is off i tried putting it in and it locked the front driveshaft so i know it can engage but what causes the grinding noise?
Sometimes it'll do that if the road is not perfectly flat.
mine has done it a few times. I would just turn the truck off and put it into 4 then vice versa for 2wd. So I am confused though, you say you turned it off, switched it into 4 and all the wheels were locked up? is this on dirt or pavement? don't use 4 low on pavement. |
I bought it a few months ago and I was just checkin to see if everything worked. I definitely know not to use 4 wheel drive on pavement..
well, 4 low on pavement. I use 4 hi if it is snowing and required.
I saw on you tube,a guy with a supercharger 4x4 chevy late model smoked all 4 tires,so much for the transfer case!
