grinds going into 4 low
i have a 94 k1500 with a 5.7 and 4 hi works fine but when i try to put it in 4 lo it makes a grinding sound. when the truck is off i tried putting it in and it locked the front driveshaft so i know it can engage but what causes the grinding noise?
Sometimes it'll do that if the road is not perfectly flat.
mine has done it a few times.
I would just turn the truck off and put it into 4 then vice versa for 2wd.
So I am confused though, you say you turned it off, switched it into 4 and
all the wheels were locked up?
is this on dirt or pavement?
don't use 4 low on pavement.
caddieb
May 15th, 2011 5:32 PM
