Mutiple cylinder misfire
Here's my story:
1.) Got a "Service Enging Soon" light - took my C1500 with 5.7 to Autozone to check codes. They give 3 different things that could cause whatever code - said most likely catalytic converters. Fixed that and code went away. 2.) A week later the light comes back on - this time Autozone says "Multiple Engine Misfire" - probable cause plugs and wires. Changed them and light went away. 3.) This weekend we were towing our RV and start getting a very loud miss trying to stay at 70 MPH going up the Missouri Ozarks. After the light comes on again, we pull into a local Autozone to check the code - another "Multiple Engine Misfire". The guy wanted to sell some more plugs and wires. The only thing I could think about at the time was the distributor cap and rotor. The old ones were corroded. This didn't fix the problem at all (add this note: when I tightened down the rear screw on the distributor I did hear a "click" - I wonder if I cracked this cap!). Now I'm wondering if the fuel filter is stopping up. With 127,000 miles, most of this stuff needs replacing anyway. I just hope something fixes this. I have to be towing to get this to happen. I can run around very quickly with AC running and nothing happens. |
RE: Mutiple cylinder misfire
I had one at 70mph did the samething injectors was going bad
ORIGINAL: cj23 I had one at 70mph did the samething injectors was going bad |
Well I have a code checker and every time it would say mutiple cylinder misfire I took for granted since it could not pin point which one I change them all.
ORIGINAL: cj23 Well I have a code checker and every time it would say mutiple cylinder misfire I took for granted since it could not pin point which one I change them all. |
I used new ones and yes there are eight.
ORIGINAL: cj23 I used new ones and yes there are eight. |
