Old Aug 10, 2015, 6:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Transmission Guides
Print Wikipost
Which rear end do I have ??
Old Jul 7, 2012 | 7:15 PM
joe in calif's Avatar
Default Which rear end do I have ??
The book says they are 2 different rear ends and there is a big difference in the towing weight they can pull. There are 2, one is 3.42 and the other is 3.73, so how can I tell which one is in my 2000 silverado 1500 5.3 V8?
Old Jul 7, 2012 | 9:41 PM
country_09's Avatar
4wd or no?
Old Jul 7, 2012 | 10:36 PM
It's a 2 wd
Old Jul 8, 2012 | 11:53 AM
ericnottelin's Avatar
The easiest thing to do is call your local chevy dealer and give the service guy your vin. they can pull up the options code sheet for your truck. The rear axle ration is on that sheet. Have done this for several of my trucks.
Old Jul 8, 2012 | 1:05 PM
country_09's Avatar
Bein 2wd in 2000, probably 3.42. But some 2wd came with 3.73s
Old Jul 8, 2012 | 3:21 PM
Allan In NE's Avatar
Jack up one rear wheel.
Turn the tire exactly two turns and count the number of times the driveshaft rotates.
Allan
Old Jul 8, 2012 | 5:06 PM
Check your RPO codes in the glove box and check it against this list
Rear End Gear Ratio for Chevrolet, GM | Ring and Pinion Gears | Chevy Ring and Pinion Sets | Drivetr - Drivetrain.com
Old Jul 8, 2012 | 5:36 PM
rpo# axle ratios
gho 3.54:1
gt4 3.73:1
gt5 4.10:1
gu4 3.08:1
gu6 3.42:1
hc4 4.65:1
Old Jul 9, 2012 | 12:57 PM
This is the sticker inside the glove box and the sticker on the door. I don't know which is the RPO code your talking about, I'm new to all this stuff. Thanks again for your help.
Old Jul 9, 2012 | 2:22 PM
country_09's Avatar
Stand corrected. Look at the 3rd and 2nd from the right columns. The second row or the 3rd column says GT4 meanin 3.73. The 2nd colum has a G80 meanin you have a g80 limited slip diff
