Old Jul 27, 2015, 3:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Spark Plug Change?
Old Apr 14, 2012 | 7:59 PM
dcoperator's Avatar
Default Spark Plug Change?
2008 Silverado w/5.3 litre @ 87000 mis. Time to change plugs? And if so what do you recommend for plugs?
Old Apr 14, 2012 | 8:21 PM
country_09's Avatar
They're recommended to change at 100,000 if they're still stock. If you feel the need to change em, go for it. Stick with AC delco iridium or NGK TR55
Old Apr 15, 2012 | 10:46 AM
Mille Racer 69's Avatar
Ngk don't really work that great on GM IMO.
I use champion. AC delco's are also a good way to go
Old Apr 15, 2012 | 11:45 AM
Unless you are replacing your entire ignition system with a high-end brand, there is no need to use anything other then the AC Delco...
If you think that you can get more performance out another brand of plug, keep in mind the same spark plug that is used in your truck is the same one use in the Corvette...
I would stick to the 100k plan unless you are seeing obvious signs of fouling to the plugs...
If you are seeing drive-ability issues you might try an injector cleaner added to the tank a few times first...
my .02 cents
Old Apr 15, 2012 | 1:17 PM
I changed my factory plugs at 102,000 with the same A/C plug that was in there from the factory. The old ones looked almost as good as the new ones did. Why change when something is that good?
Old Apr 15, 2012 | 1:46 PM
country_09's Avatar
NGK tr55s work great on gm. Cheaper alternative to the AC delco and last almost as long
Old Apr 15, 2012 | 3:35 PM
I had to check on it
Per AC Delco's site the plug needed is :AC/Delco P.N. 41-110 Professional Iridium Spark Plug
Per NKG site the plug needed is :NGK (7397) TR5IX Iridium IX Spark Plug
On Amazon:
AC plug is $4.93 each
NKG plug is $7.40 each
I couldn't find the listing for the "S" country_09 do you know what the "S" is for? (standard maybe?)
It does seem that the NKG is a pretty popular replacement for the AC Delco...
Old Apr 15, 2012 | 5:59 PM
country_09's Avatar
Lol the s is there as like a plural thing. The real name is a NGK TR55 but you need multiples of them lol. But yes they're a very popular replacement plug for chevys
Old Apr 15, 2012 | 7:12 PM
LOL! Doh!....so it does stand for something... (Stupid in my case) lol...
Yeah I have no idea why I didn't make that connection....
mamulan
Aug 20, 2014 8:39 AM
TPM
May 14, 2013 5:58 PM
ristpin
Nov 9, 2009 2:45 PM
customtie
Nov 11, 2008 4:15 PM
FckenVince
Oct 28, 2007 4:25 AM
