Notices
swapping axels?
Old April 1st, 2010, 8:02 PM
manteray's Avatar
Default swapping axels?
i have a 94 chevy k1500 and i blewup my rearend. im looking at a set of 94 k2500 8 lug diesel axels. does anyone know if they will boltup the same or if i need to do any modification
Old April 1st, 2010, 8:23 PM
maxxman04's Avatar
only problem i could see is maybe driveshaft/u-joints. gettin driveline to match diesel would probably fix that if needed.
Old April 1st, 2010, 9:45 PM
s34n's Avatar
what if they are different trannys? different size yokes then
Old April 2nd, 2010, 1:09 AM
manteray's Avatar
yea if the u-joints are different i can probably fix that at the autoparts shop or a driveline shop. I'm hoping everything else is the same though such as the upper and lower control/a arms and fitting in the same as the stock axels.
Old April 2nd, 2010, 3:50 AM
Ride of the Month
May 2009
mudmaniac's Avatar
The rear axle is no problem, the front control arms are not going to fit.
Old April 2nd, 2010, 11:18 AM
manteray's Avatar
will the 1/2 ton control arms work with the 3/4 ton axel steering knuckle setup or???
The guy has the whole frontend cut the frame just in front of the cab but i dont really want to weld anything just hoping to bolt it together.
also does anyone know a good site to get ring and pinion gears and what brand would be stronger?
thanks for all the help so far
Old April 3rd, 2010, 7:03 AM
Ride of the Month
May 2009
mudmaniac's Avatar
I don't think the knuckles would work, I think you woud need to weld new mounts on for the contol arms. You can order gear sets at http://www.ringpinion.com/ that's where I have bought mine. The Yukon gears are good ones.
I just remembered that the light duty 3/4 ton with the 6 lug axles will bolt in, but they use the same 8 1/4 front diff and CV's as the 1/2 ton.
05chevy4x4
December 11th, 2007 6:26 PM
beemerjunkie
October 11th, 2006 2:48 PM
gmcjr
Camaro
August 30th, 2006 11:20 PM
redpeppers
December 7th, 2005 12:55 AM
monster420
March 12th, 2005 8:56 PM
Quick Reply: swapping axels?
