tire pressure monitor system
I'm sure that this has been beat to death - searched and nothing came up - I'm sure I didn't search correctly.
2011 2500 HD 6.0L I finally figured out how to reset it after rotating my tires. I bought the truck used and it doesn't have an owners manual. The problem: after first resetting and adjusting tire pressure it told me that the RR tire was low on pressure - it had the same amount as the other three tires. The next day it told me that both rear tires are low - they have the exact same pressure as the two front tires. I have 60 psi in all 4 tires. Why does it think just the rears are low. Is there any way to eliminate the tire pressure monitoring system altogether?? |
I would have to guess I have everyone stumped........ at least 89 of you :)
Welcome to the forum...
You can find your owners manual here -> Chevy Vehicle Manuals and Videos | Owners Manuals | Chevrolet As for why they are reporting bad info, you might want to have the battery status read of the sensors at a tire shop... are the tires original or aftermarket, its possible the previous owner put aftermarket sensors in and they are failing.... |
thank you tons :) couldn't find an owners manual
replacement tires - the problem started the first time I had them rotated - 10,000 miles after purchasing the truck - for the last 10,000 miles I'v just been turning the warning off. |
It looks like two don't function correctly - one of them intermittently - looks like a $100 repair something that I despise.
As much as I like the truck there are a few things about it that I hate with a passion. |
I have a 2013 Silverado, rotated the tires 2 times now and have had no problem with the sensors. Are you sure they need to be reset when rotated?
there's a procedure so the computer relearns their locations on my 2011 - the sensors themselves don't need to be reset -
possibly there's still another issue - I'll try the relearn procedure again today and try more air pressure |
Don't the 2500HDs run more pressure in the rears?
After rotating, correct the pressures, then relearn, and all should be ok. (I think) |
Originally Posted by fredrich03
(Post 269316)
After rotating, correct the pressures, then relearn, and all should be ok. (I think) This is one of the problems that I have with newer vehicles. I run the truck empty 99.9% of the time and any more air pressure than the 60 psi I am running causes the center of the tires to wear prematurely. That's the bad thing about computers is that they only base "data based" and don't deal with the current circumstances - they just assume being a 2500 it's loaded and needs max tire pressure. Same with the traction control too - I hate that just as bad. :@ |
Well I fixed it :D
The tag on the door says 60 psi in the front tires and 80 psi in the rear. :eek: :mad: 80 in the rear?? Empty?? Seriously??? :confused: I went up to 70 psi and the lights went off - dropped them to 65 and the light is still off. More than I want but I guess I'll have to live with it. It KILLS me that I can't run the tire pressure that I want to run. Stupid government and lawyers. :mad: :@ http://i57.tinypic.com/10dry2v.jpg I took it off-road today for the first time too - man that traction control is a joke too. I marvel that I really like this truck as much as I do. :D |
