Vendor that sells t-case gasket set
I have a 95 K1500 that has an NP241C transfer case. The transfer case works fine with no noise, but it has a small leak. I have searched but cannot find a vendor that sells only a gasket set. Finding a set with bearings is not hard, but I don't need bearings. Does anyone have a suggestion as to who might?
Thanks, Brad |
If you can locate where exactly the leak is coming from Autozone sells single gaskets. Is it coming from the output or input shaft?
It is leaking from the output shaft. It does not look to be a bad job to change it.
Autozone sells one check this link out!http://www.autozone.com/autozone/cat...em%40108ff9%5D
Thank You Zuk-man. It is actually leaking where the output housing connects to the main transfer case. I will replace the rear seal while I have it off though. That leads me in the right direction. I will go by there tomorrow at lunch. Then, soon as my AMSoil Severe Gear oil gets here, I'll be in business.
Thanks, PS: are you ALWAYS on here? |
Im always available from 3:30 to 2:00 in the morning(michigan time) When somone post on here it notifys me on my cellphone!
I never met a Fel-Pro Catalogue I didn't like, but I've met quite a few lazy counter parts guys who didn't want to be bothered to look it up IN the cat...
Worst come to worst, there's a lot of good RTV sealers which you can use as a gasket substitute. |
