00' Silverado 1500 Heavy Oil Leak
Old Oct 3, 2009 | 4:40 AM
ChevyChic's Avatar
Question 00' Silverado 1500 Heavy Oil Leak
I just bought this truck and took it in to get an oil change and was told there was a heavy oil leak... my question is what parts can possible cause this so I can take a look at it and get it fixed?
Old Oct 3, 2009 | 11:46 AM
therewolf's Avatar
Hey ChevyChic,
Welcome to the Chevy Forums. What's the mileage of this "badly leaking engine"?
Funny you didn't notice an oil leak yourself, before you took it in. Had you been noticing low oil pressure? 20+PSI while it's running hot is acceptable pressure, leak or no. Did you have to add extra oil to keep it running?
Didn't you notice an oil slick where you park your truck? Try placing some sheets of newspaper under the engine at night where you park the truck. There should be oil on the newspaper in the morning if it truly has a "bad oil leak".
Things are tough all over, but it truly must have been a bad oil leak for the mechanic to have noticed it during the time it took him to change your oil.
The best advice I can ever offer is never take some mechanic's word for it. It always pays to verify, either by checking yourself, or by getting the opinion of someone who won't financially benefit from the proposed repairs.
As to bad parts, the rear main seal is generally the culprit, possibly the front seal. Also bad valve cover gaskets caused by a clogged PCV valve.(In which case you should have seen and smelled smoke.)
Old Oct 4, 2009 | 12:04 AM
lukemoore646's Avatar
that is odd, the only thing I have ever heard of leaking on these is the oil cooler lines and they do not leak that much
Chevy beast
Apr 24, 2015 2:41 PM
Wade Quick
63
Sep 16, 2014 8:28 PM
Chevrolet Forum News
Nov 2, 2013 3:11 PM
Wade Quick
Feb 28, 2012 1:30 PM
HeavyChevyTom
Mar 5, 2011 7:25 PM
