01 chevy problems with LED taillights
i have a problem with the tail lights on my truck. i had the stock ones on there and replaced them with LED tail lights i got off of ebay. i put the new lights in and now i dont have voltage to the connectors. the brake lights, turn signals and running lights do not work, but the reverse lights do. any ideas???
check voltage to the corresponding fuse, if you have voltage, try replacing the fuse. if the fuse blows when you either plug in the light, or try to use the tail lights, then few things could be going wrong. First, there could be a bad circuit that grounds and blows the fuse. next, could be bad circuit board that blows the fuse in the actual tail light housing. have you tried plugging the old ones in? seeing if they work? if they do, then those ebay ones are a dud and need an exchange.
Ive checked the fuses and they arent blown, when i plug lights back up they still do not work. I have no clue what is going on. Its kust not making much sense. I also change the circuit board underneath the bed today.
Tahoe fan
May 11th, 2010 1:08 PM
