01 Silverado 1500, 10-Bolt Rear Differential - Fluid
Old Oct 2, 2011 | 11:18 PM
DGorris's Avatar
Default 01 Silverado 1500, 10-Bolt Rear Differential - Fluid
Hey boys,
Noticed the rear differential was leaking on the truck last week so this weekend I got around to changing the seal/fluid. After replacing the cover with the new seal/fluid, I noticed we've still got a leak. Where the bottom of the cover meets the actual differential there is a hairline crack.
Have the new cover/seal package on order, going to replace it this weekend. One question though, what fluid is recommended for this truck? It's a 2001 Silverado 1500, Ext. Cab, 5.3L Vortec, 4x4, 10-bolt rear end.
Thanks,
-Dane
Old Oct 3, 2011 | 10:41 AM
country_09's Avatar
I used 75w-90 synthetic I do believe...which I'm pretty sure I read is what came out of it
Old Oct 3, 2011 | 2:32 PM
DGorris's Avatar
Okay, that's also what I was told, but when we changed the seal/fluid last week my buddy said 90W-140 (or is it 140W-90?), so that's we used. He said the locker in the rear end needs this (although he has a 2500 HD). The truck is still sitting and hasn't been driven since the change, so if that's not the correct fluid I still should be okay until this weekend when I change the cover/seal/fluid again.
Thanks again,
-Dane
Old Oct 3, 2011 | 2:37 PM
kevinkpk's Avatar
Thanks again,
-Dane
It's 90-140, Unless your pulling alot, and in hot weather, I'd go also with 75-90W
Old Oct 3, 2011 | 8:03 PM
DGorris's Avatar
Noted.
Thanks boys,
-Dane
Old Oct 6, 2011 | 11:20 AM
slw210's Avatar
Specs say SAE 80W-90 GL5 (P/N 10950849).
Angelski19
Jun 25, 2012 6:16 PM
kivikaitse
Mar 13, 2012 12:37 PM
tcr1016
Jan 9, 2012 4:24 PM
Stimpy911
Oct 13, 2011 2:01 AM
tbb2
Aug 13, 2011 7:06 PM
