Notices
01 silverado 1500 misfire
Old April 5th, 2012, 6:29 PM
JRush89's Avatar
Default 01 silverado 1500 misfire
i have a 2001 silverado 1500 5.3L and i am having problems with a random/multiple cylinder misfire. ive changed the spark plugs (AC Delco), replaced the intake manifold gasket, and checked the fuel pressure and checked for moisture in the fuel. the misfire also seems to be occurring on the drivers side only. any ideas on how to resolve this?? thanks.
Old April 5th, 2012, 7:40 PM
country_09's Avatar
Changed wires too? Could be messed up in the boot and not even know it
Old April 5th, 2012, 8:06 PM
JRush89's Avatar
The wires are fairly new. (2-3 years)
Old April 6th, 2012, 11:52 AM
Are you getting a check engine light? The wires could still be bad with 2 or 3 years on them. I always say do not overlook the obvious!
Old April 6th, 2012, 12:12 PM
JRush89's Avatar
Yes. My light flashes to show misfire.
Old April 6th, 2012, 4:13 PM
country_09's Avatar
If it's flashin, then that means a big misfire. I'd pull the plugs and inspect the wires just to be sure. Check the cats as well. My stock ones were clogged and caused a flashin SES light to come on
Old April 6th, 2012, 4:29 PM
JRush89's Avatar
I just put new plugs in last week hopin that was the problem. I am also gettin a low voltage to O2 sensor code
Old April 6th, 2012, 4:30 PM
JRush89's Avatar
Wires are very clean and no damage. Good connections to all 8
Old April 6th, 2012, 7:51 PM
country_09's Avatar
Check that o2 code....is it driver side?
Old April 6th, 2012, 8:55 PM
JRush89's Avatar
It don't specify for some reason
Quick Reply: 01 silverado 1500 misfire
