'03, front brakes shot, back ones great
#11
RE: '03, front brakes shot, back ones great
1. It sounds like bad rotors, or a problem in the master cylinder causing the brakes to hang, or he just rides them
2. There is a huge difference between light duty and heavy duty brakes. For one the thickness of the rotors, a 1500(light duty) has thin rotors, the HD's have Huge rotors front and rear along with better calipers to put some claming force on those big rotors.
#12
Actually I just looked up calipers and rotors for both a 2003 Chevy Silverado 1500 4x4 and a 2003 Chevy Silverado 2500 4x4 HD and it pulled up the same part numbers.
#17
ORIGINAL: NCHEVYHEVN
*edit* unless you looked up a 03 1500HD Crew, that has the same brake pakage as the 2500HD's, the standard 1500 uses a different setup.
#18
factory pads are ceramic type,last 100k +.....rear wear out around 60-80k....try this...pump the pedal several times,(engine off),crack a bleeder valve and see if it "spits" fluid...if it does,m/c seal is sticking and keeping pressure applied,(hope you dont have something other than brake fluid in there ?)...if it does'nt spit fluid out,possible booster issue....it it hydro-boosted or vacuum ?
hydrodriver
April 21st, 2010 8:06 PM
ondagaskiknass
July 1st, 2007 1:59 PM
07LS
January 23rd, 2007 11:37 AM
ImLow78
October 25th, 2006 4:33 PM
