03 silverado passlock issue.
Old November 28th, 2015 | 2:59 PM
RyGuy_420's Avatar
Default 03 silverado passlock issue.
Any ideas or a way to bypass the passlock sensor? No reference signal to I'm from sensor. I already has to rewire that part of the circuit because of resistance not allowing 5v to pcm. Now nothing is coming out of sensor and it's not a steady reading. Ranges from .2v to .5 v. Any input is gratly appreciated. Need it fixed asap. Thank you
Old November 29th, 2015 | 1:36 PM
RyGuy_420's Avatar
Been tinkering with it today and I got 5 volts at sensor signal wire with key off. When I turn key to acc it drops to .2-.5v. Any suggestions to what may be causing this. I tightened the connector wires and checked resistance through sensor all seem good. Just don't have spec sheet to verify correct resistance through sensor. Please need help asap. Thank you
