04 Silverado
04 Silverado
can anybody help me with a 04 siverado, it has a built in electric trailer braking system, but when you push on the brake pedal, no signal is being sent out of the box under the dash where you plug the brake pig tail in to
04 silverado, no trailer brake
There is no wires to check (on my side). The problem is right at the eletrical box its self. There is no signal coming out of the panal when the brake pedal is pushed. I even tested another truck to make sure that i was tested the right place.
04 sivlerado elec brake
When i tested it on the other truck, it had 12volt coming from the pin(when you pushed the brake pedal down) that would contact the plug in the area that was wired to go to the brake pedal wire on the back of the electric brake controler.
