07 Silverado 5.3 AFM oil filter?
Old October 14th, 2007 | 12:54 PM
dk1ben's Avatar
Default 07 Silverado 5.3 AFM oil filter?
Ok so I have a new 2007 Silverado v8 5.3 crew cab 2wd. with active fuel management.
My father in law has suggested using Mobil1 oil and ACDelco filter. I dont question the oil choice. However shouldnt I use I higher quality filter. He claims that I much use ACDelco filter not to mess up my warrenty. Any thoughts?
Old October 14th, 2007 | 6:05 PM
NHSilverado's Avatar
Default RE: 07 Silverado 5.3 AFM oil filter?
You do not have to run an AC filter to keep your warranty in tact. Totally wrong. AC filters are good filters up to around 5K so use them if you want but you do not have to use them.
Old October 15th, 2007 | 2:24 PM
ZX1100F1's Avatar
NH is correct, you do not have to use an AC Delco filter to keep your new car warranty in effect.
The AC Delco PF48 filter that your truck uses will perform well for the entire oil change interval as specified by your Engine Oil Life Monitor System.
Many people believe that if you use synthetic motor oil that you should also use a synthetic media type filter such as the $10 Mobil-1 unit, this is not the case.
Due to your engines design and the current quality of motor oils it is extremely rare to see an engine failure as the result of poor filtration.
At the moment there are not many aftermarket companies producing an oil filter that will cross reference to the AC Delco PF48 so your choices are going to be somewhat limited.
Old October 15th, 2007 | 6:18 PM
Here is the list of aftermarket filters that I know of that cross to the AC PF48
K&N - HP-1017
Mobil1 - M1-113
Wix - 57060
Napa Gold - 7060( relabeled Wix )
Baldwin - B160
Hastings - LF613
Purolator Premium Plus - L12222
Purolator Pure One - PL12222
Fram - PH10060**
STP - S10060**
Champ - PH48
SuperTech(Wal-Mart) - ST10060**
Penzoil - PZ167**
Carquest - 84060
** - I DO NOT personally recommend Fram, or Fram made, filters. The #'s are here simply for reference.
Old October 18th, 2007 | 1:12 AM
MagnaFlowZ71's Avatar
06 Z71 I Run Full Syn Mobil 1 Also Mobil 1 Filter And I have Seen My Gas Milage Go Up A Few Notches
Old October 19th, 2007 | 11:41 PM
Kevin's Avatar
as per the commerce department, you are NOT required to use dealer parts (likr filters) to stay in warranty. as long as the product meets the minimum requirements set by the manufacter, you are ok.
btw, WIX are great!
also use NAPA gold filters.
Old October 19th, 2007 | 11:42 PM
jimmydaleo's Avatar
another note, you will not lose warruntee work unless the part that you added is proven to have caused the problem.
Old October 19th, 2007 | 11:44 PM
Kevin's Avatar
ORIGINAL: jimmydaleo
HERE! HERE! [sm=icon_guiness.gif]
Old October 19th, 2007 | 11:45 PM
jimmydaleo's Avatar
Kevin are you trying to catch me with posts?
Old October 19th, 2007 | 11:47 PM
Kevin's Avatar
of course not my friend
why would I do that ?
