Last edit by: IB Advertising
Browse all: Exterior Guides
- Chevrolet Silverado: Windshield Wiper Diagnostic
Guide to diagnose trouble and recommended solutions
1990 Silverado Wiper Problem
#32
This is an old problem with 88 to 98 trucks.It's an easy fix. Remove the pulse module, and resolder the points where the harness connectors attach to the module. Age, temperature swings, and vibration cause the solder joints to fail. You will NOT be able to see these cracks with the naked eye. This is a link to another site which shows this repair in far more detail; 1995 wiper switch change - ChevyTalk --The Social Network for Chevy Fans
Good Luck, Mark
Good Luck, Mark
#33
I have the same problem with my wipers working intermittently. I going to have to try that dielectric grease. I've been looking for a solution to that, the wipers stopping how they do and only going at one speed is so annoying. Any other ideas?
#34
Sorry, Crusher9, that you have this problem. My wiper system continues to work well after applying the dielectric grease. It's been a long time and the initial application still works! Give it a try, and if it doesn't work for you, go back into this thread and read the instructions on how to replace the module and wiper motor with a later model.
Good luck!
Haner
Good luck!
Haner
#35
How I Repaired this Board
My Truck is a 1988 C-1500
Remove the board from the housing.
Mine has a relay with contacts like the old style Distributer Points.
Take a nail file, it is TOO thick so you will need to place it on rough cement and put pressure on the top of it and drag it across the cement to make it thinner.
I used two of these, so basically 4 sides to use.
Shove the nail file in between the contacts a few times, remove, flip 180 shove in a few times. Then repeat for the other set of contacts.
Make sure they look shinny. If not just repeat.
I then did the same thing on the Motor side contacts.
Coat with di-electric grease (The connectors, not the relay aka:Points).
Good to go!
Took about 30 min tops.
Reply back to this thread if this helped you or if you found another way to fix this.
Good to go!
Last edited by ChipHead; August 19th, 2014 at 5:21 AM. Reason: fhl69: Found a contextual error, Fixed
#36
Coat with di-electric grease.
Good to go!
Good to go!
#37
Update from Haner
Just wanted to let everyone know that since applying the dielectric grease all those years ago, my wipers are still going strong. Thanks for all the continued updates and optional procedures, too! It's cool to have other options for those of us who refuse to give up on our old trucks!
Haner
Haner
#38
Uuugghhhh!!!
Haner, I found myself at this forum pulling my hair out over my 1990 Chevy K-1500 wiper pulse board module!! After 24 years my wipers decided not to turn off anymore. They work in all settings, but when I turn off they stay stuck in 16 delay. Driving me crazy. I too went to the auto parts store and got the part that said fitted my truck (C-type). Nope!! I have exactly the same as you describe and from the pictures you included. Can not find a replacement anywhere. Doesn't even show it as existed and being discontinued. There are now 3 of us on the planet with that type. My only guess is that it was a recalled part and replaced and now it's not made anymore. The replacement part is what keeps showing up on all my searches. (It's more of a quest now!) I will try the dielectric grease and cross my fingers. Soldering connections is a little beyond my skill set. If that don't work then I guess I'll have to splurge on the whole replacement deal. I have a long road trip ahead first so will just pull the fuse for now. It's annoying not to mention looks stupid to be driving all day with the wipers on! I will let you know how it goes! Thank you sir. Dave.
#40
$100. They also had a motor for a 1990 but it took the old style module which nobody has. If you go with a new one, make sure it is for a 1991 or later. Was not a real big job switching them out.
