Notices
1991 Chevy Silverado knocking under load
Old April 3rd, 2012, 1:01 PM
  #11
Chevy-Lover's Avatar
Ohoh, doesn't sound good!
I would do the same as I did.... I bought a whole engine (including all sensors,... even the injection system was included) that was an overproduction of GM. Never used or installed, just tested.
If you want to go the same way, just give me a PM and I will help you getting the same. Price was $2450 I think.
Old April 3rd, 2012, 2:15 PM
  #12
oh, just saw it's a '91 one... so better look for a new one
Old April 3rd, 2012, 5:58 PM
  #13
justimagination's Avatar
I would suspect a head gasket leak between #3 & #5 cylinders. They are next to each other and when you get two cylinders next to each other with almost identical compression, that's where you look for the problem. Good luck, let us know how it goes.
david
Old April 3rd, 2012, 6:04 PM
  #14
Allan In NE's Avatar
Naw,
If you've got one cylinder at 70 lbs and the other at 80, don't think timing is your issue.
Allan
Old April 3rd, 2012, 7:40 PM
  #15
Gundog's Avatar
glad it worked out. Sounds like your rings are going but I would check again then put a squart of oil in the low cylinders if pressure increases it is your rings.
M.Reynolds
May 30th, 2021 3:58 AM
dslemaire
August 23rd, 2018 9:46 PM
jaysranger
May 9th, 2015 3:10 PM
rteas48183
March 18th, 2008 4:59 PM
harold
April 6th, 2007 3:20 PM
Quick Reply: 1991 Chevy Silverado knocking under load
