1993 k1500 runs and then dies
Hello, My 1993 chevy k1500 has started to give me issues. A little back story, I was in the woods about a week ago when I was low on fuel. I don't know for sure if I was dry, but when I went to head home she fired up, I gave her a little rev up and then died. She didn't start for 5 more minutes and then died right after starting. This went on for about an hour. Once she started and ran enough to move without dying going into gear, I made it 2 miles and then died again and wouldn't start. I added fuel, disconnected the battery and let it set for 3 hours. I made it home just fine after waiting, but once I got home I shut her off and fired her up, no problem. I did this a second time, but on the third try she wouldn't start. The next day it ran just fine until it warmed up a little and died again. Waited and started again then died. The following day she left me stranded, died pulling up to a light and wouldn't start for 1 day, (traveled a total of 5 miles)
Naturally I thought it was the fuel pump, I just finished replacing the fuel pump and filter, but its the same ole song and dance again. After she dies now, the fuel pump will not prime for a while. Is there a sensor that controls the fuel supply? The last vehicle that did this to me was a jeep Cherokee with a back crank position sensor, it told the ignition not to spark. Does anybody have any ideas?
Today I took a look at all the ignition components. Once the vehicle stops running from dying, it has lost spark and will not regain the ability to spark unless it has set for some time. I will replace the cap, wires, rotor, plugs and coil. Is there any sensors I should be aware of in the ignition system in regards to spark?
kirks22m
April 18th, 2014 12:22 PM
Zackman1995
February 19th, 2012 8:05 PM
branch
June 23rd, 2011 11:12 PM
pauld62788
July 17th, 2010 2:05 PM
