1994 K1500 oil pressure problem!
![Post](https://chevroletforum.com/forum/images/icons/icon1.gif)
My oil pressure keeps dropping on the gauge, i know im still getting pressure and oil as i looked in the valve covers. When i start her up the gaude says im around 40 but when i start driving it drops to 30, 20, 0, then the 'check gauges' light comes on. i replaced the oil pressure sender thinking that went, but it is still doing it. i have a new oil pump too, any ideas?
Would you describe this as fairly good pressure when cold and gets progressively worse the hotter the engine gets?<O
</O![Stick Out Tongue](https://chevroletforum.com/forum/images/smilies/tongue.gif)
<O
How many miles on this engine?<O
<O
Allan<O
</O
<O
<O
Allan<O
install a mechanical gauge and then you will know. After all you have done, it may be the instrument cluster but a mechanical gauge will assure you none the less.
Put a good mechanical gauge on it. If you're still showing that pressure dropping way off when it's hot, you've got lower end bearing trouble.
Allan
not_a_car_dude
September 15th, 2013 7:41 PM
Zeke Koob
September 4th, 2013 9:04 AM
Brettspark
July 25th, 2008 8:05 AM
werneb01
May 15th, 2006 2:57 PM
