1994 truck
#11
There ain't a vacuum leak. We hada mechanic Check it an he said so also... It only does it in drive. If u put it in reverse an give it gas it runs fine
#12
The vacuum gauge has nothing to do with checking for your vacuum LEAK, it is to diagnose your problem.
You obviously did not read the LINK I posted for you.
So, hook a vacuum gauge, read the link and see which scenario best describes your reading.
"Help ME, Help You"
Fire your so called mechanic/friend.
"Help ME, Help You"
#17
im not sure but im guessing there wasnt nothing wrong cause my dad didnt say anything or say anything was unusual with it... were ganna take it to a different machanic next week and hook it up to his computer
#18
Maybe its the fuel pump just a thought a guy could really be suprised at what problems a shifty fuel pump can make for . just a suggestion if you havent all ready get a psi reading from the fuel line then clamp the return line off and do it again with the return line clamped if it doesnt change its probably a fuel pump problem
fjwewers
March 29th, 2015 12:02 PM
mps2220
January 2nd, 2014 1:13 PM
tecate1987
November 12th, 2009 4:03 PM
