Notices
1995 C1500 need help with air distributor
Old October 29th, 2011, 11:11 PM
Kevman's Avatar
Default 1995 C1500 need help with air distributor
hello I have a 1995 C1500 has heater only bought it used found that the heat air mix control was not hooked up looked futher into it and discovered the back (closest to the front of the vechicle all the way on top) arm with the spring in it had the plactic pin out or the hole the opens and closes the vent. On further inspection the same vent is out of the holder on the passenger side. I took the lower box screws out reached my arm up inside and can feel the hole the end of the vent that has the pin on it is supposed to go.
My questions are what holds the passenger side of the vent in, I know I am missing a part that holds the switch control on and am wondering if that is all I need?
If the the vent is broke inside how do I remove the air distribution box so I can replace it? According to the Chevy parts list on my truck the vent it's self is not replaceable you have to replace the entire distribution box.
Thank you in advance to anyone who can help. Kevman
Scarecrow68
May 13th, 2015 8:38 AM
c15AUS
March 22nd, 2015 8:23 PM
murfy101
March 12th, 2014 12:05 AM
Mille Racer 69
17
November 7th, 2010 4:19 PM
evilernie6
March 9th, 2009 6:37 PM
Quick Reply: 1995 C1500 need help with air distributor
