1995 K2500 Extended Cab Diesel - Turn Signal Fuse
I just bought a used 1995 K2500 4WD diesel. I tested the lights on my trailer and must have had a wiring problem because it appears that I blew my turn signal fuse. Break lights, flashers, runing lights all work fine. No turn signals. The manual in the truck shows a different fuse block from the one in the engine compartment. The one in the truck dosen't have a fuse slot for the turn signals.
Can anybody help me locate the turn signal fuse? Of if that is not likely the problem, the turn signal relay?
Thanks
Thanks
ROTM Coordinator
ROTM Coordinator
Yes, it can be the relay as well, sometimes they stick on , sometimes they stay off. I will try to look up the diagram for your truck in a little bit unless someone else get to it first, I am going out the door right now.
ozsmiffy
August 25th, 2024 5:30 PM
fishingpro77
HHR
August 4th, 2016 12:44 AM
Cw3jperry5
March 14th, 2013 10:13 AM
RomanGuzi
October 2nd, 2011 11:40 AM
extremefourwheel
August 14th, 2008 9:25 PM
