1996 chevrolet 2500
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
V8 5.7 gas engine.
Had the following codes-mass air flow sensor, MAP sensor, and intake temperatur sensor.
Started by replacing the map sensor and intake temp sensor. Gave a complete tune up- plugs, wires, distributer cap, rotor, and changed the fuel filter. Cleaned the mass air flow sensor.
Truck still ran rough. Dies when you start it unless you keep foot on gas. When you shift from park, you have to go straight to neutral and let the motor catch up with itself. While driving, it will bog down slightly.
Had the mass air flow sensor tested, and it tested high out of range. Had vacuum guages hooked up and it shows no vacuum leak. Fuel pressure also tested normal. Replaced the mass air flow sensor and still have the same problems.
If the air intake sensor is unplugged, it still runs rough, but better than with it plugged in and it is actually driveable.
PCM is giving proper voltage to the mass air flow sensor.
sammyf
October 14th, 2013 4:34 PM
For Sale: 1996 GMC Suburban 2500 4x4 w/7.4L-IL
rowekmr
July 3rd, 2011 4:09 AM
stshadow
April 22nd, 2011 9:48 PM
Unknown1329
February 16th, 2010 7:01 PM
