1997 k1500 starting issues
#11
My 1996 K1500 5.0 L is having trouble starting. Turning the ignition from off to start in a swift motion the engine will turn over but wont start.. However, if I turn the key from off on, wait from 1 sec to sometimes 4-5 sec for the dummy lights to come on and then to fully engaged it starts with ease. It is also a stick shift if you think that could have anything to do with it but i feel sure it doesn't.
#12
My '98 K1500 has intermittent starting problems. It turns over fine, sometimes fires right up, sometimes doesn't. If it's going to fire it happens right away, so I don't turn it over and over, just quick bursts. The "turn the switch on and off 3 times then hit the starter" ploy works sometimes. It happens when I've run it for a while, then shut it off for an hour or more. It starts quickly if it's only a few minutes. Weird problem, since the 5.7 Vortec runs great all the time.
#13
It sounds like your fuel pump is not holding pressure. It's a good idea any time to give the fuel and electrical systems a few seconds to boot up before hitting the starter. Read it in my Buick owners manual.
#14
A lot of experienced Chevy guys say that about AC Delco parts. I use them now, and haven't had any parts issues since I quit buying those cheap-xxxx eBay parts.
#15
Hi I read your quote on the timing and I went to start my truck and the engine started but the rpm didn't register or speedometer didn't work and little tiny Prius power and the engine light comes on and reads out torque converter but I just replaced transition and torque converter 3 weeks ago mr transmission . And there saying it might be computer but my mechanic is saying he can't find the problem and can't guarantee that switching the computer would fix this issues . Have you ever heard of any thing or have any insight on this aggravating situation . Thanks
#16
#17
I had a similar issue at the beginning of January with my 98 z71. I replaced my distributor (the insides were rusted), rotor cap. Also I replaced the coil pack. It had a crack down the side. While I was at it I cleaned my MAP with MAP cleaner from the part store. I had a couple of burnt spark plugs so I replaced the plugs and wires. It's running like a champ.
TheEric
March 15th, 2014 10:55 AM
dudeman_85
October 25th, 2011 6:46 PM
