1997 Silverado Power Steering Pump Removal
I have a 1997 Chevy Silverado with a power steering leak. It appears to be a gasket leak as the high pressure hose is fine. I have removed the V-Belt and the PS Pulley. My problem is that I am unable to remove the pump. According to the Haynes Manual I have removed all of the necessary bolts (there are three of them). I have also removed the bolts from the A/C pump, but the PS Pump just won't budge. Am I missing something? PLEASE HELP!!!
on the pump there's a bolt that sticks out, me and my friend had a hell of a time with that one. you need a "puller" that will get it off..we got lucky and one of my other buddies had one in his shop
Stuck Power Steering Pump
Thanks, but I got that part off. My problem is that even AFTER I remove the pulley bolt and the 3 bolts behind the pully wheel, the pump still won't come off. Thanks for responding!
it should come off relatively easy after that....although we had to hit it with a hammer to knock it loose lol check for other bolts on the backside that may still be holdin it on...im not sure if there was one or not
breezy
February 9th, 2015 6:01 AM
Danmc00
February 18th, 2013 9:02 AM
jft7032
December 11th, 2011 3:24 AM
hunter10220
May 18th, 2011 8:37 PM
davo davis
June 20th, 2007 5:33 PM
