1999 Silverado 1500 won't crank - IP not working
1999 Silverado won't start - IP lights not working
My Silverado was running and starting fine until yesterday. I put it up on ramps to remove aftermarket running boards and then it would not start. I had battery load tested and it checked out fine. (12.6 V) When key is put in sometimes the door open chime will sound (door is open) and sometimes not. Chime will go off when key is turned. No crank, no IP lights, no gauges no odometer only turn signal indicator lamps come on sometimes dimly. I checked ground to cab and was good. Interior light appears dim when it comes on. Anyone got ideas?
ctlawless
2007 - 2013 (GMT900)
61
April 4th, 2024 1:54 PM
RitualJman
14
May 9th, 2017 2:02 PM
Katiemay
September 1st, 2015 9:21 PM
