1st post brake question
Hi, real rookie here, I have a 98 Z71 pickup with 74,000 miles on it, lately the brakes are pulsing quite often, does this mean the sensors are bad? is there a way to just disconnect and no longer have anti lock brakes? is this something I would want to do? had a guy tell me there was a way to do this as he paid 600$ for new brake sensors and had he known he would have just disconnected the sensors. Thanks in advance.
Frank
Frank
RE: 1st post brake question
Golfer, I appreciate your reply, the brakes arepulsing and collapsing like they would if on a slippery surface about 50% of the time, no abs light lit, if warped rotors would I not feel it all the time? I was told if the abs were disconnected it would then just act like a normal brake, is this not the case?
ORIGINAL: 03rubicon
Golfer, I appreciate your reply, the brakes arepulsing and collapsing like they would if on a slippery surface about 50% of the time,no abs light lit,
I do hear the abs actuator coming on, as for why to disable the abs, no other good reason other than to save a buck, not poor by any means so I will bring it in to have it looked at and fixed.
It is possible to have a false ABS brake activation in situations that do not warrent ABS activation. If the sensors pick up a bad signal they think they need to work but the driving situation doesn't warrent it. The sensors usually get a bad signal from water intrusion into the sensor or wiring, a cracked, heavily rustedor damaged reluctor ring and will often not set a code because the system thinks it is working properly. You can determine if the pulse is from the ABS system by pulling the fuse(s) for the ABS and then driving the vehicle. If the pulse is gone it would seem to be the ABS system. With the fuses pulled the brakes revert to the base brake system which we all are familiar with. If you ABS system is at fault, a technician needs to monitor the sensor signals to determine which one(s) are giving a suspicious signal.
I don't have any 1998 vehicle information here but I just checked my 2005 Silverado Owners Manual and it has a nice illustration and description of the fuses. Check your Owners Manual for that information. The ABS fuse probably feeds only that system.
I had the same problem on a 2000 GMC Sonoma. I had the abs sensors replaced along with the shields and rotors. Pretty much worked. If you take the fuse out your brakes will work for everyday use, but if you ever have to slam on it, they'll lock up on you and you'll slide into disaster....
With the ABS fuse removed your brakes will act just like brakes have always acted prior to ABS. If you slide into disaster it is because you don't know how to use your brakes. ABS allows you to still steer the vehicle while using the brakes near lock-up.
