Notices
2 or 4 Barrel?
Old October 24th, 2007, 9:37 PM
  #11
RonH's Avatar
Default RE: 2 or 4 Barrel?
ORIGINAL: mudderfan
it is carbed, so i will check
Are you aware that a throttle body fuel injection looks pretty much like a carburetor? Take off your air cleaner over the (whatever it is) and look down inside. If it's one big hole with a single plate that opens and closes, it's a throttle body injection.
Old October 24th, 2007, 10:41 PM
  #12
mudderfan's Avatar
ok so it is throttle body. i checked. i feel like an ****. so any new answersseeing as it is throttle body?!
Old October 25th, 2007, 8:13 AM
  #13
RonH's Avatar
A possible problemis fuel supply - low pressure from the fuel pump or clogged fuel filter. If you can have someone check the fuel pressure at the test port, that is the best course. If you can't do that, then start by removing and checking the filter to see if it is clogged.
jkann1
March 6th, 2011 12:58 PM
dulcebigblock
October 12th, 2009 8:52 PM
Sharp77
September 15th, 2009 9:36 AM
Kalispellbob
July 9th, 2009 7:52 AM
porshapower
August 21st, 2008 2:14 AM
Quick Reply: 2 or 4 Barrel?
