2000 Silverado 5.3 random misfire/cylinder 6 misfire
Hi, when I let the truck idle the engine light flashes, when I drive the truck the light will not flash and sometimes it will go away!! Truck has plenty of power runs great when driving but at idle you can feel it missing!!! I have changed plugs,wires,ignition coil! I was thinking maybe fuel issue so I hooked up a fuel pressure gauge and at idle it goes down to 42psi I give it gas and it will go to 48 psi. I have changed the pump twice today with same results, I also changed fuel filter and blow out the lines from fuel rail to fuel filter!! Please help.
24compact (December 9th, 2022)
Hi I bought the
Delphi Fuel Pump EFG0407 it was the most expensive one at AutoZone! Normally Delphi is good! I will get another tester and see if I get a different reading. Do you think it could be the intake gasket? I did spray it with carb&choke cleaner and found no issues! Thank you for the reply I really appreciate it
oilcanhenry (December 10th, 2022)
Hi I bought the
Delphi Fuel Pump EFG0407 it was the most expensive one at AutoZone! Normally Delphi is good! I will get another tester and see if I get a different reading. Do you think it could be the intake gasket? I did spray it with carb&choke cleaner and found no issues! Thank you for the reply I really appreciate it.
I believe that you are correct about the fuel pressure gauge working properly. I believe that you have an intake "leak" somewhere, as I will discuss further in the post above.
I kept getting a misfire code on my 02 Silverado 1500 2wd ext cab 5.3l and replaced everything and still kept getting the code for misfire , reset computer, disconnected battery, and rechecked everything and still got the code, turned out to be a minuscule crack on fuel pressure regulator vacuum hose, replaced both regulator and hose and it was gone. Wish I would have tried that first, I’d still have money in my pocket, but $10 and Rock Auto and 5 minutes later purrs like a kitten again, hope this helps someone else before they spend a small fortune before finding out like I did. Good wrenching…
oilcanhenry (December 12th, 2022)
The man was a professional tech.
Wherever he is, I hope he returns he comes back here, but we still have really good Techs/Mechs here. Gumby22, Chem_Man, Repairman and OldChevy and many others are my equal, if not beyond, an old truck-driver who first studied in automotive technology, when I was a young man, who knew how to "turn a wrench". We are all here to help you and everyone else. It is what we do, without any thanks or response from.our advice to anyone who asks for help in a repair.
Do not give up so soon. Diagnosis of the issue is 80 to 90 percent or higher, in regards to repairing a vehicle, 24compact.
